i need rubber tyres, the plastic ones dont grip, and if you turn it just spins lol. guess i need to work on my control
has it got a rear locked diff, If not liquid nails will do :)
Can you adjust your camber and toe, If so try 2deg frount and back camber and try just half throttle at first
Not his fault. Car infront slammed on brakes, so did dad, guy in the 4WD with the roo bumper behind dad, was looking to the left, then when he looked to the front he slammed on his brakes, but obviously not quick enough.
Apparently theres two nice long tyre marks on the road out the front of the Aussie pizza shop on marion road lol.
dunno what it stands for, but they have a cruise 2nd sat of every month, always have a big turnout!
i wanna cruise sat night :/
i aint stayin home with a house full of chicks, that dunno when to keep there voices down!
Anyone wants 1 of those yokomos got 1 here i want to get rid of got in to nitros its got the half platic half rubber tires abnd a battery charger for the car battery. Its got a white s15 with the big drift wing exhaust and some rays look wheels
Just got off the phone with the old owners of my house, they will be moving out at the end of the month :/ and i'll be moving in. So putting the turbo's on the skyline will have to be put on hold for now, but still hope to have them on before the end of the year.
spent the last 3 or so hours washing, clay barring, and putting a few coats of wax on the celsior, still needs a polish and a buff, but f**k, paint looks like glass, dont think it was even that clean when it rolled off the showroom floor.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
