haha, at first i thought ben was doin it on purpose, then he pulled over and i was like
oh ohhhhhh........ thats not good.
but thankfully it wasnt anthying bad!
spewin we missed the tunnels though!
Craig, continuing from the accident thread.
I get looks and sAfrican Americans all the time man. Every from my own family, especially my dad.
One night at tea we were sitting down eating and I was telling him something about my car. He got up and walked into the kitchen came back with the bin and put it on the table then said to me "Here, put your money in here" and walked out.
yeah, some people just dont understand the passion mate.....
my GFs mum was the same, but i got her good,
she smokes and plays pokies, atleast i had something to show for my money!
I WIN OLD LADY!
you work hard for your money, do what you wish with it imo!
cant you just weld it up Cubes, or is it totally stuffed??
I could try all though the heat may? damage the actuator, nothing to loose though I guess lol.
I need to replace the actuator any way as when tuned the most boost it would hold was 17psi and now with similar ambient temps its down to 16.6psi.
Wound a heap of preload on to it ~10-15mm but made no difference. The gate is being blown open which is partially due to the dump design but its better than having boost creep as its easily fixed. :)
if you get water onto it straight away it should stop the heat travelling down the metal, if you can get it off i could have a go at welding for you as i work at Ascott welding :P
Edited by DSTROY
Thanks for the offer but its all done. I only have an arc welder but its fine for little jobs like this. The weld appears to be plenty strong.
The old man has a mig but be buggered if i can get the travel speed + wire speed + amps + gas all sorted out to get a decent weld. :P
Now to find the end bit that screws on and attaches to the wastegate flapper arm. Hopefully I didn't leave it in the engine bay last night when it was dark while I was cursing. :S
FREE STUFF!!!
-bleed valve
-rb25 top radiator hose
-R33 door sills
-rb25 turbo heat shield
-mushroom pod filter (not the best for the bigger power cars (sufficated my 33 after 3000 rpm)
come get it if ya want anything.i dont need it!
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
    • I'm interested,do you still have it?
