in response to $100 dolla bill thread which is better :D numbers dont lie bitches. taken from my orginal gtr special hpi mag. that decimal of a second means im like 1cm in front n stuff.
clearly my penis extension r32 is bigger and therefore better at compensating my lack of manhood than your 33s n 34s
Edited by Inline 6
i could also be agrued that they are progressively faster around a race track through the gen's as ive seen vids of the 33 and 34 smoking a 32 gtr around the race track. i believe alot of that is down to the attessa reprogramming making the newer more 4wd in the corners havin a lil more torque from the motor.
i got love for all of em but 32 will always be my fav, 34 is the best around a race track and 33 is the best value for money i think we can agree on.
and craig i dont diss peoples cars :) because after you drive a $300 dato for 7years its usually me on the recieving end of car disses. gives all a laugh though :P
if they made em smaller id want that 1 too :D 2 seater only 240z style would be crazy
Edited by Inline 6
aerodynamics, improved suspension design, improved chassis design, etc, would all play a fairly important part also. 32 had very little in the way of aerodynamic aids, 34 however...
lol Dan, I can show you figures that have the 34 GTR doing the 1/4 in 12's and 0-100kph in 4.5sec (stock standard)
they say vspec 2 32 can break into 12s aswell, they all just the reg gtr times hpi pulled.
alternatively sled you can pull your gtr out and line me up, its on mofo :banana:
*eye of the tiger beats playing in head
tempretures n tyres n such could play a factor in it when its that close, its a bees dick diff in there times. and i think a ztune should easily pull that sled :P
also note sled im an accountant(numbers obsessed) and i used to read every single magazine that spat out 1/4 mile times for skylines and como's (jus scouting the enemy boys) thats around about what they usually put them at.
^^ i thought u thought (get smart voice) i was dissing peoples cars, never mind all good dude my care factor is very low.
Edited by Inline 6
