in response to $100 dolla bill thread which is better :D numbers dont lie bitches. taken from my orginal gtr special hpi mag. that decimal of a second means im like 1cm in front n stuff.
clearly my penis extension r32 is bigger and therefore better at compensating my lack of manhood than your 33s n 34s
Edited by Inline 6
i could also be agrued that they are progressively faster around a race track through the gen's as ive seen vids of the 33 and 34 smoking a 32 gtr around the race track. i believe alot of that is down to the attessa reprogramming making the newer more 4wd in the corners havin a lil more torque from the motor.
i got love for all of em but 32 will always be my fav, 34 is the best around a race track and 33 is the best value for money i think we can agree on.
and craig i dont diss peoples cars :) because after you drive a $300 dato for 7years its usually me on the recieving end of car disses. gives all a laugh though :P
if they made em smaller id want that 1 too :D 2 seater only 240z style would be crazy
Edited by Inline 6
aerodynamics, improved suspension design, improved chassis design, etc, would all play a fairly important part also. 32 had very little in the way of aerodynamic aids, 34 however...
lol Dan, I can show you figures that have the 34 GTR doing the 1/4 in 12's and 0-100kph in 4.5sec (stock standard)
they say vspec 2 32 can break into 12s aswell, they all just the reg gtr times hpi pulled.
alternatively sled you can pull your gtr out and line me up, its on mofo :banana:
*eye of the tiger beats playing in head
tempretures n tyres n such could play a factor in it when its that close, its a bees dick diff in there times. and i think a ztune should easily pull that sled :P
also note sled im an accountant(numbers obsessed) and i used to read every single magazine that spat out 1/4 mile times for skylines and como's (jus scouting the enemy boys) thats around about what they usually put them at.
^^ i thought u thought (get smart voice) i was dissing peoples cars, never mind all good dude my care factor is very low.
Edited by Inline 6
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
