Oh cool so I can lose the massive text then? :down:
*edit* yep after looking at it just now when my post showed up, doesn't really need to be that big aye :D
*goes off to my controls...
Edited by AndrewJZX100
well i just got pulled over by cops..... saw them come up so i stopped and got out and had my licence ready, he said this your car mate and i was like yeh it is sir. then he said just take it out of the garage and i was like yeh bit dirty hey. he was like rego'd under your name. i was like yep. then he was like have a good night.. wow i was shitting myself.................
The speedo cable is way to long.. I unclipped the speedo cable up front and have it looping down slightly.
Hard to explain, get under the car have a look where the speedo cable comes out from the firewall and see the brackets that its attached to. Remove the attachment so it loops more so then it will be the correct length.
ah yeh i understand!! thanks...
gearbox is making noises all of a sudden :down: god damn it! its like i can hear bearings turning... the more revs the louder....
sometimes i wish i still had the 20!
went the vertex front bar??
how about sides and rear?
yeh got it dirt cheap off a mate.
Just got the vertex front bar atm with the type m skirts and rear bar but i have got a vertex rear bar sitting at home...still deciding wether to put it on or not??
Edited by vinnie32GTS4
HA! see even the coppers love no kit + fitment :down:
Good to hear nothing came of it.
got my 32 back today...absaloutley loving it :down:
only a couple things need to be done like wheel alignment n what not but yay
heres a pic i took with me phone
Hey man, looks good, but whats with the non matching head lights???
gearbox is making noises all of a sudden :) god damn it! its like i can hear bearings turning... the more revs the louder....
suck it up, you've just done a whole comversion so be patient with it. Not everything goes perfect first time. Your few little issues have been very minor. I bet it's the thrust bearing that i told you to replace hehe.
It'll all work out in the end.
Good to hear about the cops!!
Edited by Ryanrb25
suck it up Princess, you've just done a whole comversion so be patient with it. Not everything goes perfect first time. Your few little issues have been very minor. I bet it's the thrust bearing that i told you to replace hehe.
fixed, much <3 :)
Did you replace the spigot or more importantly make sure the motor had a spigot?
Mate of mine did similar.. Assumed there was a spigot. Ended up stuffing the input shaft bearing. :S
he he sorry! yeh im very happy with everything!! yes i know the thrust bearing :)
haha i dont know?? ryan??? lol
haha cubes its funny you say that, ive run into that problem a couple of times in the past etc and now i check religiously...yea the motor had a spigot and it was healthy. It it most likely the thrust bearing that i recommended to change but never got done. These things happen.
yeh i should have listened! sorry ryan... :)
thats something i can deal with ne ways!!! and its puerly my fault.. at least everything ryan has done has been 100%
adrian= fail hahahahhaa
ryan = WIN
    • Have you flushed the initial fluid yet? It should look like a rainbow unicorn shat glitter into it. 2nd or 3rd fluid change is when you party.
    • all brand new unit from Tomei, fluid, bearings, etc. Tomei said they call it a 1.5 lsd because its 100 percent lock up under acceleration and 50 percent under deacceleration.  as I mentioned I used their fluid, install and their break-in procedure, (alot of figure 8's) but even when driving straight, or even slowly backing out of garage for first time, (at 2 mph) then driving to and from figure 8 parking lot, each tire in the rear would sporadically grab, skip, bounce, shutter and skip, shutter back a force I could feel causing clutch to slip then grab, at any speed. shaking entire car. I removed unit, since I put stock back in and all is fine, via process of elimination, its something with the lsd unit itself. I wasn't going to beat up the entire car more or change anything else for no reason as I had a feeling something in the lsd itself was wrong as everything was fine before this alone was installed and I rechecked over everything else after first time backing out I suspected an issue. I'll probably sadly already need new tires now just from trying to drive it 5 miles and performing the figure 8 break in. but if someone has any ideas I'm all ears
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
