running RACING GEAR coilovers
sounds like top quality stuff imo
just as good quality as D2 :blink:
never heard of em ;\ maybe get yrself some isc adjustibles, or barring requirements for street legal, some bilsteins or teins ?
glad u werent doing 200 when those went on you. hell even 100 would have been really bad
-D
-D
yeah ,
gonna get ISC's or TEIN for xmas hopefully
hey cheers to everyone that came to lukes party last night, good to see you all. I was pretty ermm drunk when most people got there.. and I suck at Beer bongs haha. I kinda inhaled it instead of drank it..
No invite for dohmar *sob* /wrists
i forgive u, i was off plotting world domination so its all good
-D
Err, what? Racing Gear make quality parts and have been around for years, they're not G4/D2 kinda shit. Sounds like human error with installation could be a factor (not pointing fingers).
BTW I just remembered I saw you on Greenhill road this arvo mitch, I was the bloke in the stock white 32 4dr on Glen Ossie looking like death warmed up, getting stuck into my kfc :D
:blink: Pinky and the Brain was one of my favourite cartoons as a kid, I used to be able to do the best Pinky impressions :P
white 32 with a black roof ?
i saw ya haha , me and my mate ( who was in the black R33 ) were like , i wonder who that could be :O
gee brain what we gonna do tommorrow night
Edited by AndrewJZX100
Yeah thats me.
Car looks good on the road man. Must've been before the coilover incident :blink:
your car looks thug aswell
haha yeah it was, was on the way to autobahn to get cleaning products and then to kfc :D
i spilt kfc everywhere when my coil dropped haha
It looked better when it didn't look so damn stock (or damaged :blink: ) but coppers cruise past me without a second glance now and sometimes they don't even take notice of my car at all, so I'm definately not complaining :P
Which is how it should be really. I'm driving around obeying the laws like everyone else (well, everyone who isn't a business man in his commo or tradie in his ute/van doing 80 in 60 zones and whatnot :D ), why the hell should I be targetted simply for the type of car I drive?
i know the feeling all too well , i get smiles from cops lately , had 2 cops come up to me at mt lofty a couple of weeks ago , they liked my car :O
It looked better when it didn't look so damn stock (or damaged :blink:) but coppers cruise past me without a second glance now and sometimes they don't even take notice of my car at all, so I'm definately not complaining :P
Which is how it should be really. I'm driving around obeying the laws like everyone else (well, everyone who isn't a business man in his commo or tradie in his ute/van doing 80 in 60 zones and whatnot :D), why the hell should I be targetted simply for the type of car I drive?
penny, id go and find a 31, think youll have a bit of trouble with the 'rolla.
Gentlement, prepare to be hypnotised ...
Clicky linky ... http://vili.us/hypno.html
:thumbsup:
so... distracting...
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
