Power just went out at my place :down: i sure hope it comes back on soon :)
i feel for you man ive go to drive upto mt barker and check my car out + the comohore im driving the a/c pipes are busted lol.need to get new one's for the front of car.
bring it on.
i wouldn't move to Melbourne parents choice or yours Mitch.?
parents , both got offered jobs down there with their current employers , and as we moved from melb to here a few years ago
they want to move back down there as all our family is there etc .
i cant afford to stay here on my own earning $250~ a week so im probably packing up and moving down there :down:
:down: Power just came back on. Aircon FTMFW!!!!!
Same! What suburb are you in? My work lost power for 90 minutes (Dulwich) and all the traffic lights along dequetteville were dead (not flashing, dead dead)
Ruby, did u get affected?
-D
-D
Morphett Vale, power only went out for 20 minutes.
-D
I'm working at Eastwood. We're on the same grid as the old ETSA building, so I doubt we'd lose power :down:
I'm working at Eastwood. We're on the same grid as the old ETSA building, so I doubt we'd lose power ;)
Hah! Famous last words (cos sooner or later somethin's gonna blow)....
Eastwood eh.... Clint Eastwood?
-D
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
