dedicated skidder unfortunately. would only come out for the larger cruises/driven the long way to a workshop...
seen it in the flesh, thing looks mean as, spesh with the full set of model 5's on :)
yeah, same, looks tough as. aussie kept the 5's when he traded it for the 100 im fairly sure. has some meshies on it at the mo which ill have my way with, probably rock a few sets of dori's as skidders.
Yeah, they looked gangstar on the 100 too :)
Dunno who's got them now, but it looked pretty good on those meshies anyway at the BSM cruise.
That 32 is taking a piss :)
My Stag does the same thing up my work driveway. Work mates have asked about it ... I just say the car is taking a piss! :)
Edited by RubyRS4
