I would love to get an EVO6 TME but I just don't know enough about them to mod them. Wouldn't know what size wheels fit etc etc.
I'm just looking for something different than the Skyline. I can still mod the Evo6 without attracting the cop heat as you would a skyline or silvia. But I'll have the "nice girly lancer there mate" comments
Nothing girly about an Evo. Girly lancers are those that have GAY bodykits and ugly wheels attached with 'Ralliart' decals
You would get it from the stupid people that couldn't tell the difference. Would be a good sleeper though if you took all the EVO badges off. Rip afew big V8's :haha:
But then who gives a f**k what 'stupid people that couldn't tell the difference' think anyway! :(
man up, cupcake.
get a comment like that, smile, cue witty retort, side step at 6 grand and enjoy.
^^ what for?
well??
this could be taken as 2 ways as in how much are you hoping to pay and
why do you need one to clear regency to borrow or because you don't want dogs bollocks sitting in your engine bay saying please send me to regency
Mine leaks
Pfft Nissan shit.
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
