i missed the shit fight, but i could care less. had an awesome night out.
but yeah, in regards to all that ns/sau shit, i hang shit on everyone and everything, and despite the shit ill sling at ns, i dont mind it over there, theyve got some fairly awesome useful and entertaining shit on their forums, a bucketload of sponsors, and theres always cool shit for sale.
and lets face it, who else would be capable of organising such large cruises?
Mine didn't get fitted this arvo as it didn't fit....yet :D
mine wasnt fitted either, was slightly frustrated about that. was made to suit a t25, not my t28, not too fussed about it, it was caused by a slight hiccup in communication, and andrew is gonna fix it all up for me tomorrow, even offered to come by my house on saturday to mod and fit it for me. ended up just dropping it off at lukes workmates place so he can take it in to get it fixed while hes having his exhaust done. but yeah, another big +1 to andrew at AM, even with all the little hiccups fitting it, hes been uber helpful with everything.
Edited by scandyflick
ur 1st paragraph, 1 sentence 1 question. sh*t used 5 times. 6 if you include in the lil prelude sentence.
vocab use crap in there a couple of times, like the crap im giving you now.
lol sh*t fights are the most entertaining part of these forums i thought :D
just looking at my rb25det some more and i came across this :@
snapped exhaust manifold stud, and its missing another 4 .
HOPEFULLY nissan somewhere in adelaide has some !!!!
would order off just jap but the have a minimum of 12 and i cant afford to replace shit i dont need to replace
I went past and had a good chat to Andrew last night and he'll go out of his way to make sure anyone who buys components from him are 100% satisfied. 110% for customer service that's for sure.
Now make sure you don't do the Saturday thing because I'm hoping he's going to have a look at mine tomorrow morning :D
Is it safe to come back? :D
When to get the Brutale out today to ride to work. Flat battery. I think I'm gunna need a new one. Still charging it up tho for a ride tonight. :)
lets not forget my pick up line "can i liquidate ya assets" good for a smak in the mouth everytime
:P
Thank God I'm just a measly bookkeeper :P Even at my age, I can still pick up and not get slapped across the face.
Dear Valued Forum Army Gang member,
I have become recently aware that our gang name and my senior position has been meet with snickers. Took me a while but I figured out what they making jokes of, apparently people have made changes to what our acronym stands for, Their saying we are the Forum Army Gay's. Also direct abuse to me, changing my prestigious senior position tittle of "son of rajab of the F.A.G.'s" to "the gaylord"......... ..har har.........very childish. Don’t get me wrong I have a sense a humour but some things are uncalled for. :D
After looking at many options I feel we have no choice but to change our name, im proposing "Power Over Obstruction Friends". Felt this is a tuff sounding acronym that cant be made to sound gay, it also represents the obstructions we have overcome to start our club.
Now who's with me my fellow P.O.O.F.'s
Edited by Inline 6
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
