man, I gotta say, to all those poor folk surviving on a pension - fark it isnt easy
not complaining, not at all, but for the desperate out there in diar straits it just doesnt work. seriously you find yourself watching every single dollar
damned lucky I paid out my morgage, but how could some one on a pension afford rent/bills/etc?
you know its been 1yr now since I went onto disability support. erroded all my savings, lol stupid car
but i have my house -- Hoorah
:down:
another rant about adelaide roads... a guy from work was driving his r34gtt last week at night and hit a massive pothole = cracked rim, f*cked steering rack, heaps of other suspension damage... repair bill was sent to local council, but how many times will they have to pay for damages before they f*%$# learn their lesson and fix the f*#@% roads?? couple of weeks ago a bus i was riding got f*cked when it hit a pothole, hit the kerb and nearly ran off the road onto footpath, yes even with those massive wheels youre not safe... jesus f*#%@ christ, who runs this city??? blah... :down:
...and thats what grinds my gears
Dave have a look at these guys in the US as well.
http://www.deatschwerks.com
i have not heard of any issues with there injectors as they are all flow matched and i bought some off of the already and it was great service.
About $450 delivered for 550's at the current exchange rate.
Cheers
I have used these's injectors a few times and they are unbelevable.
Interesting. Are the injectors for the RB25DET different to that of the RB25DET Neo motor? ($399 for 550cc for RB25 as opposed to $459 for 440cc or $549 for 600cc for Neo)???
I had thought they were the same ... Neo or non-Neo?
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
