Ok, installed an air vs fuel ratio meter that i got form jaycar... now its not the most accurate thing out there... but the fact that i built it and wired it in
merits some satisfaction :P Just thought i'd share! :D Oh coincidently the alarm beeps when i need to change gears! WOO
Edit* Looks cool at night too!! with all the little LED's dancing around XD
Joel you need to learn to read thats twice now you've been given an answer today and you still asking the same question
i told you up the said check your afm elec. Cleaner might not be enough Damo there over 20 years old
my car almost got defected :D
luckily i got an awesome cop who has given me a week to get EVERYTHING fixed
he did say if he sees it on the road next week in the same condition he will defect it.
oh and my suspension is too low :P which is weird coz no1's lowered it unless my
brother did it it without me knowing lol
yes, yes i do. went from a job with random hours at a low-ish pay rate to working the last 3 month with consistent hours at a high-ish pay rate this = mega tax refund!!! =)
same! thankyou ATO :P
What do you mean Joel? The plug
you need to unbolt the whole lot and spray the needle on the inside and dont use degreaser
lol damo ner ner...
could be.... i pulled the top AFM off to clean it but it was already sparkling so i didnt bother about the other 1.... maybe its worth looking at...
those chromies on your car damo look crazy when the spokes are painted with 2pac gloss black! a mate of mine did it and they're not bad at all
I was going to say the same thing :P They look pretty good but would look alot better with black spokes
200-300 for the front bar sprayed maybe?
but when i went to arnedale to pick up my mum there was a freaken RBT on the street where the carpark is where bunny had her cruises! cop asked if i had a bov i said yes and it's stock, he let me through :P
Guest
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
