ok guys looks like this MIGHT not happen tonight coz my car is still at the shops.
for those who are still interested PM me you mobile number and i will send out a mass SMS if this goes ahead.
thanks for the pics Mag86.
Ash
well my car is out
heard from RE customs and all that needs to be done now is put the turbo back in and bolt everything up connect all the lines up so ye wont have my car till monday.
BUT im still in :w00t:
ill be with Dilmah in his GTR so this is still going on.
meet point can still be the same unlees you guys are to worried about cops then PM me your mobile number and ill sms you a meet point
yous till up for this Andrew?
Thanks for the great night Ashneel...
And thanks for making me think I'd been done by a speed camera... ( :wub: )
hahahaha the look on your face was priceless :laughing-smiley-014:
but all in all was a fun night. we did have a tine bit oof trouble with finding the right roads (dont bother with a gps :cool: ) but the roads were awesome.
thanks to all that came was a good and long drive lol
Moe your evo is f**king insane. ill see you on the GOR cruise.
was awesome fun keeping up with you in your evo moe, you obviously know about the cornering limits of your car better than i do... i was driving too slow :)
we gotta do that again in the dry one night, the roads were awesome!
see ya all on the GOR cruise
