K, i just fitte dmy new T3/4 turbo to my R33, and i must say it was extremely impressive. However it seems to be that no matter what i am running aorund the 13psi mark... is that because it has a 13psi actuator spring maybe? Cos i have a turbosmart boost controller and it still seems to run that same boost level no matter what. The thing that is different on this turbo to the stock R33 one is that the line from the wastegate actuator connects onto the compressor housing and the boost controller t-pieces out of this, with the stock turbo the wastegate actuator line runs to the intake piping via the standard boost controller. Is it becuase i am by-passing the factory boost controller that it is no longer limited regardless of the turbosmart bc i have? Cos i really want to turn it down a notch to around 10psi if i can but not sure how to run it back through the stock bc.
Also it seems that i have rediculous flutter lol it is very loud and goes for ages, i'm talken like 15 secs if i hold it there under load when i back off. Is this okay? It seems to be the BOV aswell fluttering and doesn't really sound like its all compressor surge. What could it be causing this flutter ot be so big and will it cause damage?
Any help will be great.
https://www.sau.com.au/forums/topic/18850-boost-and-flutter-issue/
your new turbo may have a 13psi actuator fitted to it, this can be varified by running a hose from the actuator to the comp housing on the turbo but first remove your turbosmart boost controller. If the boost is steady on 13psi your turbo has a 13psi actuator. If this is the case re-connecting the factory boost control will not lower the boost level. It is quite safe to run 13psi through these engines as they run extremely rich with the stock ecu (so rich that it can cause the engine to loose power at high boost levels)
cheers
Thnx heaps dude, that is how i got it running at the moment, i have the hose running from actuator to the comp housing and the boost controller t-pieces out of that line, so i might just remove it and run it at 13psi i think. Only thing is it runs a lot smoother with the boost controller than without, doesn't seem to be jerky boost so i might leave it on for that reason.
So 'mort' you think my O2 sensor could be shyte? That'd explain the dodgy reading on my autometer air/fuel gauge aswell... very unstable reading on that... cos i get around 350-360 a tank and that was before the new turbo, it seems to use slightly less now aswell weirdly? Not sure, but yeah.
    • You can’t see much on the other side as the lcd is there I don’t think it’s the same as the m33 beside it as the markings on top is not the same was hoping someone had a good quality photo or if they just happened to have the unit in hand, quickly take the cover off and take a photo to clearly show the marking on top to identify the diode   the unit is currently with an electronics repair shop so I can’t take another photo at the moment hopefully they are smart enough to know if it’s a zener diode or not
    • I'd be very surprised if you can buy new OEM mats. But if you can, I want some too!  Do you have links to the variations you found? Also, where are you located? I found that Nengun is happy to list items to purchase but when you do buy them you'll get an email that it's actually discontinued. As far as I know the variations in floor mats are different colour schemes as well as automatic and manual having a slightly different shape. The automatic ones fit into a manual car without issues, but I think you'd have trouble fitting the other way around. I have photos that show the shape difference if you care. FWIW I bought sets of used floor mats in decent condition at yahoo auctions.
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
    • Hi, Marek here 🙋‍♂️. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
