Updated!
Hey there,
Just having a look at where the leak is coming from, it seems it's more on the drivers side of the car, I think it may be a heater hose.
It's leaking onto the starter motor, then onto the gearbox which is making it drip a little further to the passenger side.
I just wanted to know, has anyone had this problem before? I heard its a common issue with the R33's - whats the best way to fix it?
Edited by KustomR33
https://www.sau.com.au/forums/topic/189050-heater-hose-coolant-leak/
dash out is probably less fiddly than trying to leave it in.
bypass the heaters lines within the engine bay by linking them together with some copper pipe, then buy yourself a new core.
Then do a search in the Gen Maintenance section and DIY section for a guide on how to replace the core.
tricky thing about that part of the engine is that there are alot of coolant hoses under the plenum as well as the heater hoses.
check out the heater hoses first as theyre easier to get to.
just look out for the hose with the most chalky residue on it, look for a split in it and go from there.
as for getting under the floor mats, it usually is a broken heater core that leaks into this area. some people have gotten away without ripping the dash out but its a little fiddly as the heater core sits right behind the centre console up against the firewall.
Edited by SECURITY
I just read this thread.. yes you got shafted .. you have to remove the starter and put it on a hoist and get a seriously long rachet peice with a rotating head ... takes about 2hours but I had to replace the actual heater metal rail, harder than any damn heater hose which I could change with my arm and plyers..
I'd hit up those mechanics for dodgy bullshit mate.. if they do it that way tell them to f**k it up again and leavelol.0
may i further add you just have to drop the box support and rotate the engine with a jack if they want to do it that way .. so again i prove them wrong.
Btw to the first post, it sounds exactly like what I had .. metal rail or the coolant line on the rail .. its sitting under the plenum check whats leaking first .. put it on a hoist
Edited by DECIM8
    • Was there ever a model of the Stagea m35 that didnt have a badge on the grill? I thought I saw that somewhere, some aero edition or something? I cant find it again? davemoto
    • Its a 2002 vr-x four VQ25DET, silver. Coil overs, lowered, polished alloys and sport exhaust. Bit of a project, was sitting in a shed for a while but runs and drives great.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
