Hey there,
I'm after the following parts for a R33 GTST Series 1:
1. Drivers Side Regulator (Little Black Box sits inside the drivers side door)
2. Plastic Dash Surround (Goes around steering wheel and CD Player)
4. Passanger Side Runner (Plastic Peice on the passanger side that says "Skyline")
Anyhow, if you could PM me your best prices sent to Brisbane (4127) that'd be good, thanks.
Thanks for your time, regards - Aron.
Hi Aron,
Ill get back to you re postage to Bris,
For the Drivers Side Regulator im looking at $50,
For the Plastic Dash Surround $70,
and for the Passanger Side Runner $70.
Thanks for youre time and ill let you know sap for the postage,
cheers,
Chris.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
