Hey im probably going to get a k&n air filter but just wanted to know do you hear any sucking noise compared to a pod filter??
i just got my car imported and it was serviced with a new air filter so i dont know what to do yet but its a recaro brand filter.
https://www.sau.com.au/forums/topic/189214-kn-filter/
hmmmm thought so :domokun:
i want low-mid torque for launch n that but i want the sucking noise too
A pod filter doesn't really mess with your low-mid torque at all.. That would have more to do with your exhaust,clutch,tyres in most circumstances..
https://www.sau.com.au/forums/topic/189214-kn-filter/#findComment-3410373
but doesnt k&n give u better response when accelerating and pod filter give you better top end speed or high end torque something like that
It's been said by some members on the forums here that they've noticed a little lack of low torque after putting on a POD.. But I think the gains/differences aren't that noticable.. You're car just breathers cleaner, should run a little more efficiently, get more km's per tank of fuel. I had a boxed POD with cold air intake on it on my old 33 GTS. That seemd to give me the best of both worlds.
https://www.sau.com.au/forums/topic/189214-kn-filter/#findComment-3410397
yeah if i go with pod im gone need heat shield and good setup so it breaths cold air properly...and im not to good at all this stuff
There's a member on the forums here called Maxx he makes and sells the boxes for R33's anyway it just replaced your stock airobox, encloses the pod, has a clear plastic top so you can see in and still keeps the stock snorkel feed.. See below. If you wanted to get more out of it I'd set up some PVC piping or something from the front bar to blow underneath the pod aswell.. More air can't hurt.
https://www.sau.com.au/forums/topic/189214-kn-filter/#findComment-3410446
i have a yellow paper panel filter on my r34 im not sure what brand it is but it was on it when i got it. anyway above 4000rpm i can hear a sucking noise it sounds pretty cool. and in my old car i had a k and n air filter and it used to make more of a whistling noise, but both weren't really loud but you could hear them without the radio on.
https://www.sau.com.au/forums/topic/189214-kn-filter/#findComment-3410572
I started with the stock airbox, went to a pod in a cold airbox with cold air feed, and then back to the standard air box with an Apexi panel filter.
When I changed back to the standard air box, I could notice the following:
- less top end pull
- much better lower end torque for day to day driving
- quieter
If you decide to get a pod, definitely get a heat shield and pipe some cold air to it. I'd recommend a dry/paper filter, not an oiled one like K&N. In a test the Apexi filter had the best filtration and flows just as well or better than the others. It is dry so you can just blow it out with an air compressor when it needs cleaning - ie no messy oil kits.
https://www.sau.com.au/forums/topic/189214-kn-filter/#findComment-3419844
I used to have a Apexi power intake pod but recently noticed it was dirty so i put the stock air box back on again. The car runs the same, if not better (smoother?).
I could only hear the suction noise if the bonnet was open otherwise i really didn't notice much of a suction noise that everyone goes on about. IMO save your $89, spend it on something else :D
btw you might find this useful, it gives a comparison on the different brands: http://www.mkiv.com/techarticles/filters_test/2/
Edited by shaun123
https://www.sau.com.au/forums/topic/189214-kn-filter/#findComment-3420960
I could only hear the suction noise if the bonnet was open otherwise i really didn't notice much of a suction noise that everyone goes on about. IMO save your $89, spend it on something else :)
You should have cleaned your pod!! It makes a massive difference.
I agree that the Apexi pod does not make much sucking noise, but it is louder than the standard box.
hmmm i have my mind made up one minute then change hahhaha
$89 Apexi Pod
or around $100+ for K&N panel filter
i still duno yet :)
im sort of leaning towards k&n Panel filter
I'd go with the panel filter :)
https://www.sau.com.au/forums/topic/189214-kn-filter/#findComment-3421670
I find the K&N panel filters to give better responsiveness. As a daily driver I just find something like this to suit my needs. But if your really out for the the intake sound, go for the pod, but as everyone said, let it at least have some cold air feed.
Just wondering what pod filter to get on my 34 gt
I want a sucking noise
which pod delivers on that... personally i was gonna go blitz but not sure
what you guys think???????
tahhh
Most likely the Blitz and K&N Pod's. I haven't used apex'i but as far as I can see it won't be as noisy as the two brands. Though I've heard that some cheap brand Pods use cheap oil which can make the sensor dirty reducing performance.
https://www.sau.com.au/forums/topic/189214-kn-filter/#findComment-3440003
just changed from k&n panel to apexi pod. found the pod to be heaps better and fixed the problem of oil slowly getting onto my air flow meter and stuffing up my a/f ratios. if your gunna use a panel use a dry one, not oiled. :O
https://www.sau.com.au/forums/topic/189214-kn-filter/#findComment-3440038
i was thinking that aswell... thatnks for the help mate
cheers bud
https://www.sau.com.au/forums/topic/189214-kn-filter/#findComment-3440050
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
