Which date suits you best
14 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Hiya everyone
Thought after the last cruise that it was about time i organised another one. Thinking of heading up North something like York for a bbq lunch with a little bit of a country drive. Have two dates in mind have made a poll so that you can vote on the best weekend for you. Once we have a confirmed date ill post up some details :domokun:
This will hopefully be as good as the others that i have organised and hopefully it will also provide a chance for the new stagea owners to come and meet the 'old crew' but it will also give us a chance to check out the new rides that have come to Perth over the last few months since the last meet.
Cheers everyone
Wildcat
p.s for those who dont have their stageas yet or for those that want to come along, im sure there will be rides you can tag along in or your more than welcome to bring your own cars :P
DATE : Sunday 11TH NOVEMBER
TIME : 10am meet 10.30 leave
Bring a full tank of fuel
Picnic Gear + cooking utensils
Bring lunch (bbq areas will be available for those who are going to bbq with us)
Cameras
Edited by Wildcat
https://www.sau.com.au/forums/topic/189215-wa-number-4-cruise/
  • Replies 71
Gun there was just recently a skyline cruise with the wa'ers. Of course skylines are welcome on the stagea cruise but this is obviously something the stagea folks look forward to as not many attend the sauwa 'skyline'cruises
Hey Gun as wildcat said, skylines are welcome and u would be surprised how many stageas there are, i think we had about 10-15 cars on the last couple of cruises from memory so its not bad, not 100+ cars like a skyline cruise i must admit but its better with not a huge amount of people so u can have a chat with everyone etc.
can i be the honorary non-stagea driving attendee again? my new car will be here this week. :)
ps: shoosh brad. :down:
Nah - I got that gig in mah Datsun Sunny - 1200CC of pure powah!!!
Brads not the only one you have to worry about....I know what u got! :)
always welcome Mitchy you know you dont have to ask :)
Dale are you going to come to this cruise...either with your datto or hitch a ride with someone????
I can't say for sure until I have negotiated with She Who Must Be Obeyed, but I would be interested if someone will offer me a ride (Hint Hint Sean!!!)
As for the datto? I was joking! But, maybe if I hooked up a 250hp wet nitrous kit so I could keep up, it would be an interesting experiment to see if the engine would last the day :down:
yeah kinda.. it should arrive in about 2-3 weeks, but then it has to be rego'd, and all the other shite that goes with it.. and i want to give it a good checkover, new fluids, filters, etc before i even contemplate taking it on a cruise..
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
