why lower the price....
justify why i should lower it.
if your asking me to install it clearly u dont know shizen about car audio.....it actually makes you more credible in telling me to drop the price.
price is firm.
i dont mind staring at this gear for a little longer...too many 14-yr olds roaming forums these days.
someone buy it! but before you do, ring an audio joint...get prices on new gear then come to me.
end of rant....!
:w00t:
https://www.sau.com.au/forums/topic/189402-sold/#findComment-3452064
price is firm.
end of rant....!
:w00t:
https://www.sau.com.au/forums/topic/189402-sold/#findComment-3452067
No offense intended buddy... just meant, try lowering the price a bit and then you will probably get more offers.
And yeah, I wouldn't call my self an audio pro by any means.
Good luck mate.
https://www.sau.com.au/forums/topic/189402-sold/#findComment-3452241
haha. its all good. was sinkin a couple before i was gonna head out n and after recieving soooo many offers of 450-500bux (through pm - people not even interested enough to ring) i had to vent my frustration.
i'm not making this up. i originally put it up for 700bux for a quick sale...?
600 is rock bottom.
take it easy. :rofl:
https://www.sau.com.au/forums/topic/189402-sold/#findComment-3453017
    • Thanks mate, couldn't find in VIC, ended up ordering one from NSW, getting rwc to get new plates and registration done.
    • Before all the EFR fan boys come in, have a look at: https://www.garrettmotion.com/racing-and-performance/performance-catalog/turbo/g-series-ii-g30-825-58mm/ It also comes in a T4 1.06 divided housing. I would dare say if you want response & also decent power, this thing would chop.   AND apologies, just re-read your post, you've already bought the turbo... whatever you do, make sure you stick with divided housing and proper twin scroll manifold.
    • People have got to stop doing that. ShatGPT is not a search engine. It is a hallucination factory.   I also would recommend the 1.05. The .83 will "work" for you , in that it will be more responsive, but I think you'll find that it won't be anywhere near as good running it out to 8000rpm as the big housing will be.
    • Decided for the first time ever I would tow my car TO the track day on the same working theory as bringing tools and spares "if I have it I wont need it, but if I leave it behind i will 100% need it" all setup and ready to go out and try these A050 for the first time First session showed I needed to stiffen up the dampers a touch but still managed a few 1:21's without much effort. things were looking good. Came in a dropped the tyres down  to 26/28 as they had gotten to 35/33C from 22C cold The first lap of session two I managed to drop into 1:20's. Then in the second lap into the second session. Coming into T3 and I suddenly lost brake pedal followed by some huge rear end vibrations and scraping sounds. Got it back into the pits after session ended and found this. in the attached video, all of the wobble is in the hub its self, wheel is mint, and bearing feels tight. lKXLqpd - Imgur.mp4   Deciding it was a bent spindle I tried to find bearing/hub assembly locally but was unsuccessful so it was loaded back onto the trailer i luckily brought it on to drag it back home
    • 1.05 you’ve gotta let it breath
