ther have been a few thred going around about this with prices and details but basically, if you can do it yourself you will save heaps. i did mine myself, removed everything, got the broken studs out and put it all back together and all up it cost me.
around $75 for a new exhaust manifold gasket from nissan.
about $60-70 for all new studs, nuts and fat washers.
abit of coolant and oil that got let out from removing the turbo.
and a weekend of work. spacing it out so i didn't get frustrated with it.
and dont attempt this without having access to a right angle drill.
if you don't think you can handle removing the studs yourself i've heard the mobile thread doctor guy will get them out for you for fairly cheap.
i would be paying 1k but i'm fine with doing the work. i think you may find materials would come to a few hunderd after a slight mark-up. $200-$300 and the rest is labour.
Oh ok cool. I might get under there on the weekend and have a look at how difficult its going to be. I've got all the tools (except for a hoist) but I dont know if I could be bothered with the hassle of doing it myself :dry:
I've been reading around the place that a thread fixing bloke should only be about $100-$150 so thats not too bad - saves a bit of the heart-ache anyway!
Thanks for your help mate! :D
hey jon
las time i had mine done i contacted colin the thread man.
he's around your area i think, the manifold has to be removed and i supplied my own studs and washers (2 were snapped)
cost me $90 about 1yr ago
also he comes to you.
Edited by silver gts-t
Yeah I think it was Colin.
Good bloke. Roves around a fair bit. Very reasonable. I had a seized turbo to manifold stud. Couldnt get it even when welding a nut on the end..He drilled it out for me. There was still some thread left but he decided to put a helicoil in to make it more substantial.
Threadman
Phone: 0414 237 354
Address:
Mona Vale NSW 2103
P.s. The exhaust gasket is around $100. Turbo to exh gasket $33 (If you get trade). Colin will have the studsfor the exh manifold. The turbo to manifold studs are 1.5 pitch oneside and 1.25 the other. You can use the standard 1.5 to 1.5 ones if you use different nuts. Otherwise get those 4 studs from nissan
Edited by benl1981
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
