Hey all,
My engine is in the process of being rebuilt, with forged pistons and rods, 33gtr crank and the like.
I am in the deciding stage of whether to harden up and pay for blueprinting or to scrooge on it.
I know many of you will say since the engine is apart, I might as well, as the saying goes do it once, do it right.
But the money that I wouldve spent on that could be put to buying a new alloy radiator with change left over to pay some much overdue bills.
I know what blueprinting is, but I would like to hear your opinions on whether it is worth doing in my application (street 450-500rwhp, with perhaps monthly circuit stints). Will it make a noticeable difference?
Cheers
https://www.sau.com.au/forums/topic/189723-blueprinting/
I was under the impression that blueprinting was ensuring all the components are machined to very close specifications to each other, to the most exact tolerances possible?
My understanding is that this increases the longevity of the motor, making the engine run more smoothly and reliably.
Edited by Yawn
https://www.sau.com.au/forums/topic/189723-blueprinting/#findComment-3418243
i also thought that was blueprinting as well... i got my vl turbo blueprinted
https://www.sau.com.au/forums/topic/189723-blueprinting/#findComment-3418270
blue-printing is rebuilding an engine to manufacturers factory specifications
why would you want to do that for an engine that has to make more power than the factory intended?
this has to be incorrect... They blueprint V8 supercar engines..
https://www.sau.com.au/forums/topic/189723-blueprinting/#findComment-3418884
Blue-printing is making sure the crank, rods and pistons are balanced as close as possible my making all the rods and pistons the same weight and machining the crank so all the counter-weights are the same weight etc.
https://www.sau.com.au/forums/topic/189723-blueprinting/#findComment-3418900
These days blueprinting has become the term for rebuilding to exact specs.
In the old days that was machine and assemble to the specs drawn up on blueprints - ie now cad or similar. (you've seen Mythbusters)
Idea being with a "blueprint" and full balance you get all common components machined and balanced to very tight specs. Result being you minimise unwanted variations that may add to dynamic balance issues, vibrations, .... etc. ie you end up with a sweet engine if you get it right.
FWIW I would be doing it while its in bits especially if you are going to push the output.
https://www.sau.com.au/forums/topic/189723-blueprinting/#findComment-3419075
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
