  • Replies 60
Posted Images
no mate no dyno sheet but its not hard to see by lookin at other cars and compairin what has been done if needed will get a dyno sheet
Edited by DRR33
Wow...
so it made 258HP (192.5kw) on 6psi
and 320HP (238.8kw) on 18psi.
But it makes 402HP (300kw) on 10psi like you said before?
Must need a tune..
Or does the turbo start turning backwards after 10 psi?
Maybe you can go back and edit your BULLSHIT posts.
then have a moderator delete this post for bagging out your bullshit lies.
+1 lol
very strange thread indeed.... drr33, not so sure im a believer of what is being said here lol
id love to see some of these dyno sheets... you seem to have a nast hole in your power after 10 pound
+1 lol
As i have said before this is what i got told when i brought the car by the owner and by the company that built it i put it on the post cause i hadnt had it dynoed yet and as iv said i will get it done again if it is needed
thanks
hey mate not sure how much power its making but ive been told that its will make 400hp+ atw, going to strip this weekend for qtr mile time, got 5 spoke 17s, body is good but needs paint has been painted by previous owner but needs to be redone, no sunroof, there is more stuff on the car than i said but cant think of it.
this is one of my fist post if u read it u will see that i said ive been told that it makes 400+hp.
so once again if u dont like whats in my post keep it to yourself
hey mate, i got a r32 gtr carbonfibre wiiiidebody. with new 10-point cage, bride seats, NEW g-gram wheels 315/30/r18 semislicktyres. all this thing needs is a engine. which maybe can arrange. i got a complete rb25t manual package or s15 sr
cannot be registered though. perfect racing car.
pm me if interested in more info
Edited by IMPORT-G
