hey all i got me pack in mail today about final battle
an was just puttin it out there for entrys for it
we hav 6 spots to fill
on entry u will b given
free entry for ya car
free competitor pak (tshirt etc)
free buddy pass
sponsor products
an certificate
ur car dosnt hav to hav power, looks, sound system etc all in one
u may hav standard body but be a sleeper you are welcome to enter as this is a club entry so they are lookin for a range of mods etc
so only serious ppl post after this, entrys hav to be in by the 6th nov an show is 1st an 2nd dec
post a pic up of ya car an mods so other members can see whats gonna rep us over there
https://www.sau.com.au/forums/topic/190324-autosalon-final-battle/
free buddy pass
sponsor products
an certificate
did you get an invite to compete in "invitational class"??....we got a pack in the mail to compete in the "Power Challenge" as the Power Champion for our state.
yeh 'invitational class' for best car club
cool we may see you there. Bodyform are re-kitting our car and lining the stripped out rear interior with carbon fibre. A Top Secret carbon rear diffuser and Gannador Aero mirrors as well. It should look the goods and turn the Dyno at around 600kw with the NOS turned on.
Dan mate i hate car shows with a passion, but heres a thought.........
If you can't get enough people who can afford to take the car over and enter, speak with Sinful and or DIRTgarage and organise to make up numbers with some Sydneysiders, I'm sure they could find some top representivies to help us out! and they are local! Its not SAUSA v SAUNSW!!
Something to think about.......
i was just lettin anyone in SA now first as it was SAUsa that was selected, i may not be goin yet either was just letting other members now that might be interested
once again your car dosnt have to be full show spec as this is a club entry so only has to be clean an hav couple mods, even emaculate standard will do
but would be nice to have one to rep dyno an dB as the more things u participate in the more chance hav of winning club champs
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
