Had planned on fitting my stock air box back on and bought this about 2 months ago to go with it. I have since decided to just leave the pod i have there untill i swap motors.
I have had it sitting there since, only opened it to look at it has never been fitted or done anything but go in and out of the box, once :nyaanyaa:
i paid 80 inc delivery from access autoworks and am willing to sell it for $60 pickup or $70 posted australia wide.
I am located in brisbane, please contact me via PM.
Cheers guys
Edited by 2630GTS
https://www.sau.com.au/forums/topic/190532-new-apexi-power-intake-filter/
