Hi, yes it is the same engine. I took the car to my mechanic and it was just a case of the timing belt being put on one tooth out and a broken waterpump but it comes with a replacement water pump. I've just had bad luck with skylines since the time i bought it so i'm just selling the car in parts now. Just to clarify. the engine is in good working order now...
if anyone needs any other parts off the r33 body pm me.. thanks
https://www.sau.com.au/forums/topic/190691-sold/#findComment-3442530
BUMP BUMP BUMP..... engine is out of car now.. i'm dropping the price to $650 but thats the lowest i'm going need to have this cleared asap.. CMON PPL someone must want a cheap rb25det engine witha all manifolds.
https://www.sau.com.au/forums/topic/190691-sold/#findComment-3457675
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
    • Did you hit up the search function? R33 and greddy and cable returns this thread with some options.   https://www.sau.com.au/forums/topic/358214-rb25-throttle-body/
    • Thanks buddy.. the standard one needs to be about another inch or inch and a half longer. Thanks anyway
