Going To Japan March Next Year, Tips?
alright guys
after a long wait ive decided to take the plunge n stop modding my car to take a trip, ive been doing a bit of reading up on the forums and stuff just wanted opinions/tips from people that have been there, so far im looking at going in march 08 oh and i wanna check out that harajuku place whack!
thanks guys
Edited by anfo
https://www.sau.com.au/forums/topic/190837-going-to-japan-march-next-year-tips/
From what my friends have told me it's best to know someone in Japan. They can show you around and meet new people, and help with the language barrier.
Other than the obvious, start learning Japanese if you haven't done so already. I've only been doing it for a few months and plan on going late next year.
How long are you going for? Obviously you are into cars, but what else do you you wana do/see over there?
I dont know how the aussie dollar will keep going, but it might be a good idea to buy some yen in the not too distant future. I am heading back to stay for a year or 2 in april, so I am gonna buy a couple of grand soon- (when i was there last living last year $1 = 85yen, whereas now it is $1= 105yen)
If you are into general sight seeing stuff and you have the time, go to Hiroshima. I lived near there and it was a really cool place.
Having said that, I wish i had of spent more time in Tokyo and Osaka (both to live and sightsee). It seems like there is always something cool to do there.
Also check out the dates for the Super GT calender, you might be able to get to a meeting(a must). They are PHAT.
If only we were allowed to go that radical with the V8 Supercars.
Cheers
Probably for a few months, but not that long. I'd say less than 3 months (unless I can land myself a job there :(). I'll check the dates to see which is a good time to go and better soon take advantage of the stronger aussie dollar.
Yeah I love sight seeing. I love Japan's country, people, food and culture. It has always fascinated me. I'd definitely check out Hiroshima cause I remember doing a paper on this back in high school about the war. It might sound really geeky or call me an Otaku but I wanna check out Akihabara. Gonna get me some computer parts while I'm there. Would also love to go to Kyoto and see some of the old buildings.
If I can I hope to see some street and track drifting, and if possible to try out drifting myself while I'm there. Theres so many things on my want to do list, but I just can't think of any right now :) .
Oh I'd also check out Harajuku. See if I can recognize any anime characters LOL :laughing-smiley-014:
yeah im definately keeping an eye on the super gt, and harajuku is a definate and my gf's friend is living in japan so free accomodation! my the looks of it id be staying for about a month or 2
oh and thanks for the info guys
Edited by anfo
LOTS to do/see, just post more specific questions, any shops you want to see, for events, the local drift/tack days are the best for fun and meeting people, but the big ones will be superGT, or D1, heres D1 schedule for first few months...
Rd.1 3月29日(土)30日(日) エビス (EBISU)
Rd.2 4月26日(土)27日(日) 富士 (FUJI)
Rd.3 5月24日(土)25日(日) 鈴鹿 (SUZUKA)
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
