Hey all Just wondering what models came with sunroofs and is it the only difference between the non sunroof R34's?
Did they come on a particular year of R34?
Thanks
My 1999 R34 GTT has a sunroof and its a spec 1, not much help but its a start :spank:
https://www.sau.com.au/forums/topic/190893-r34s/#findComment-3436845
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
