iv got an rb20 turbo
no shaft play
does not blow smoke
done 90k
has an rb25 actuator
selling as i have an rb25 turbo now
turbo is in PERFECT condition
located in melb SE area
wanting $150
MAKE AN OFFER
need this gone!!!!
PM me all interest and questions
https://www.sau.com.au/forums/topic/190996-rb20-turbo/
no shaft play
does not blow smoke
done 90k
wanting $150
MAKE AN OFFER
need this gone!!!!
The old RB20 actuator on the RB25 turbo for more boost trick 10psi instead of 5psi
https://www.sau.com.au/forums/topic/190996-rb20-turbo/#findComment-3438244
