hey guys,
ill start of with what the car has done to it
r33 rb25det s2
-ITS turbo good for around 260rwkw - almost in
-nismo 555cc injectors - about to go in
-nismo fuel pump
-turbosmart BOV
-FMIC
-split dump/front pipe into 3 inch exhaust
-hks pod
-splitfire coilpacks
im getting a pfc but it wont be ready for a month or so yet as its still in the guys car
my question is, will it be safe to prime the oil lines, start the car and bleed the cooling system without the pfc or will the car just overfuel and do damage or something im not talking about driving the car anywhere, just let it sit the and idle while i get the radiator and everything done
any help cool
sam :O
Edited by sam5709
https://www.sau.com.au/forums/topic/191162-starting-car-after-upgrade/
worst it would do its foul the plugs. could always go in to the inj/ign section of pfc and temp take some fuel out if it seems like its running real rich. thats what i did when i upgraded injetors to get it down for a tune.
start and flush it before you do the injectors if you don't have the pfc. It'll probably idle with the 555's but it might not and then your stuck waiting for the pfc to arrive before you can do anything.
550cc's... ~33% more fuel.
Wait for the PFC unless you don't mind replacing your plugs. :)
You don't need to start the car to bleed the cooling system.
2ltr coke bottle, chop its bottom off. Bit of suitably sized hose that slides in to the neck of the coke bottle; slightly trim down the hose so that it fits snug in to the neck of the radiator filler.
Turn the ignition key to on; remove the bleed bolt on the plenum; start filling the car up until water is squirting out of the bleed hole; keep the water level in the coke bottle above the plenum. Replace the bleed bolt let it sit a little recrack the bleed again; repeat a few times and the 99% of the air will be removed from the system.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
