rb25det done just over 100000km comes with every thing like ecu wiring and hit motor was perfect bought it of this forum for my r32 but now i dont need it as i sold the r32 the motor was in the car running fine before it was pulled out for me need this gone going very cheap im in melbourne prefer local pikup pm me for more detalis
Edited by CRMIN-4
https://www.sau.com.au/forums/topic/191291-fs-vic-rb25det-complete-1000/
offers people i need this gone asap i was gonna put this im my r32 becouse i thought i spun a bearing but now i have decided to sell the skyline and a vl calais turbo so no need for this anymore
interested in $1000 and will pick up,cheers mate
  • 4 weeks later...
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
    • There's restrictor pills in the stock boost control hoses. That's how they set the amount that was bled off and hence the "high" boost setting. The usual mod in the day was to remove it and send the "high" boost setting up to about 14 psi.
    • Thanks Duncan, that's the best info I've read. Furthermore after learning about the PCM programming side controlling the factory boost solenoid, the purpose of the solenoid is to "bleed" boost when pin 25 is earthed, thus allowing spring pressure in the wastegate actuator to overcome diaphragm boost pressure, thus closing or reducing the position of the wastegate flap creating more boost as the turbo is able to spin faster. It's pretty cool to see a designated Pill to do exactly this, would have liked to have seen it with a tiny filter over the end for those moments in vacuum.  The constant bleed pill has now been removed completely from the system and solenoid boost control has been restored once again.   Case closed 😂
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
