Hi All,
I have decided to get some different rims for my car.. I have had these rims for about 4-5 Months & I bought these off ppoz.com
The rims are currently on an S14.5 & I am led to beleive they will fit on an S14/S15 with standard guards as the fronts & rears fit my car fine before I did any guard work.
Will fit all 5 stud skylines without any hassle I believe.
Genuine Work Meister - S1 3 Piece - These are the ones which have the little studs the whole way round the dish.
White Centres with Polished Dish
Fronts - 18x8 +32 - with 235/40/18 Nankang NS-II's with about 70% tread
Rears - 18x9 +30 - with 265/35/18 Federals with about 80% tread
1 Tiny miniscule bit of gutter rash on 1 rim, all other rims are in immaculate condition.
Pics will come very shortly..
$2200 ONO
Contact via PM or on 0402 813 018 - Located on the North Shore of Sydney. Can send interstate or international if buyer is prepared to pay for it..
Edited by Shypo
  • 3 weeks later...
    • Before starting any work, we attempted to adjust the tune. However even after adjusting it to certain extremes like completely stopping fuel, it had no effect. What fixed it was removing the Nistune Board and installing the original EPROM instead. This immediately fixed the issue. Everything should have been fine with the Nistune Board installation, so I am unsure why it has caused a problem. The soldered connector is also properly soldered. This worked when I first got the 550cc injectors, before cleaning, but that may have been a coincidence.  We ended up not installing the fuel pump hanger (at least for now). So currently running stock injectors, stock fuel pump, stock fuel pump hanger – Well everything stock except the exhaust. Now I have around €1400 in Nistune, Injectors, and Hanger collecting dust for the time being, perhaps I'll install them in the future. For now I'll enjoy the car as is 😁 Thanks a lot for all your assistance, I really appreciate all the help you have given me.
    • The turbo can’t be the issue. They’re proven to make much much power than you’re making. There is something in the setup that isn’t correct. - has the exhaust got any silly step downs? - what exhaust manifold?
    • Ok, just the way you wrote it made it look like you had the stagger the wrong way around
    • I was getting anxious with the DVLA not knowing if the paperwork is fine or not, so I rang them. No update had been given, but I  was reassured that providing the box was ticked on the V750 then the application will go through fine. I've been checking the DVLA website pretty much every day, in the hope that it would have been done. Fast forward to Monday 29th  and I was greeted with a new screen on the check, and it finally showed as Taxed and MOT'd, woohoo! The car was in desperate need of a clean, not knowing when this day was coming it was put off. As far as I was concerned I had another 3 weeks  I'm not normally one for using snow foam, but I wanted to give it another try It hasn't cleaned up too bad considering it's 21 years old and lived on a boat for a number of weeks. The personalised number plate is J2 XBK, an illegally spaced number plate would have it read J2X BK. BK could either represent  the colour black or Baker, which is my surname. I filmed the first drive, the Youtube link will be at the end. I used the same driving route I did with the 323F V6 when I had a new exhaust installed, heres a couple of photos A few more since then Youtube video can be viewed here: https://www.youtube.com/watch?v=TjkFHPzjGDw
