I am Looking for: R32 GTR parts
- Rb26 valve covers/cam gear cover/and spark cover.
want to do some air brushing, so please not any damaged pieces.
- the small silver interior clips that are inset in the dash and whatnot, that you would screw the dash surround and console into. (need about 10-20)
- Hard pipes for the intercooler
- OEM GTR clock (mine crapped out on me)
- Solenoid for Blitz DSBC type R (or anything compatible)
- drivers and passanger side glass (must be in perfect shape)
- any window rubber or trim inside or out. must be in really good shape and not have any holes or cracks.
- Apexi power intakes with the adaptor.
- Skyline rocker panels, you know the ones that you see when you open your door. i need some. But the screws cant be stripped and they have to again be in really good shape.
- Gunmetal Chibi wing. (really can be any color. but gunmetal prefered.)
- greddy rad pipe
- Cable from lever to trunk.
Shipping is to canada, Alberta, edmonton. . incase you want to have a shipping quote ready. Thanks and take care.
https://www.sau.com.au/forums/topic/191625-wtb-r32-gtr-parts-assorted/
we can help with
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
