Make:Nissan
Model:R32 GTS-T
Milage:140,000km
Colour: Dark Green
RWC supplied?
Currently registered? NO
Price: $7,500.00
Contact: 0404846772
I am selling this car for a friend the current modifactions include, BOV, Exhaust System, Suspension.I do not know the full extent of modifications made to car but will be finding out this weekend along with some picture taking.
Edited by Rj34GTT
https://www.sau.com.au/forums/topic/191651-dark-green-r32-gts-t/
Compliance status?
Make:Nissan
Model:R32 GTS-T
Milage:132,000km
Colour: Dark Green
RWC supplied?
Price: $9,000.00
Contact: 0404846772
any problems with the car
As far as i know, nothing..
You can come inspect the car if you wish
Only problems are the vents in the interior of the car, which can easily be fixed. apart from that just your basic wear and tear that comes with the age of the car, but nothing too major probably just a little fade inside.
Just give me a ring if you wish to check out the car
