Cruse This Weekend From Gawler To Via Adelaide Then To M Bridge
hey guys just wanted to know if any body wanted to go for a cruse this weekend we will head out from gawler to adelaide then to m bridge then where ever havent made a time yet just wanted to see if any body was interested and it should be raining this weekend should be fun :) if youre interested just let me know cheers
spelling 'cruise' properly will add legitimacy to your thread.
also, despite how 'fun' cruising in the wet must be, most would avoid it.
this aint no spelling bee contest i just wanted to know if any body wanted to go for a cruise if they cant figure out what im trying to say stuff them and i only wanted to know people that wanted to go not people who want to bitch about it
ease up princess.
perhaps your poor spelling was irrelevant, but it was so damn obvious...
also, my point was perfectly valid, i wasnt attempting to discourage people from going on your cruise, i was however trying to give you a hand for the next time you get a 'cruse' set up.
cruising in the rain is a widely recognised no-no. grip goes out the window, braking distance increases, all the bad variables, get worse, this normally ends up with a damaged car or worse.
next time, pick a warm, dry day, well, wouldnt even need to be a warm day, just pick a dry a one, put a bit of thought into it, and then post. that way you dont have assholes like me picking your post apart :ermm:
ease up princess.
next time, pick a warm, dry day, well, wouldnt even need to be a warm day, just pick a dry a one, put a bit of thought into it, and then post. that way you dont have assholes like me picking your post apart :dry:
lol - how many times did you check your spelling and grammer on that post before adding it :P I agree tho. Rain = bad.
lol - how many times did you check your spelling and grammer on that post before adding it :) I agree tho. Rain = bad.
dictionary.com does the job lol
im sure he didnt plan it to cruise on a wet day...besides, some of us have AWD :w00t:
November rain is so random, i just did some gardening so its all good
leave the poor dude alone his just wondering who wants to go for a drive, im sure he couldnt plan the rain, and stop bitching about it if you dont wanna go simple then dont f**king go
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
