The Proxes 4? No haven't used em before.
I've got the T1R's, I haven't regretted buying them. If you like grip then the T1R would suit you. The grip in the wet is unbelievable.
Proxes 4 is the tyre down from the T1R so it probably isn't bad, but it won't be as good. It'll probably be good if you like a reasonably good amount of grip and you don't really try to push your car to its limits.
https://www.sau.com.au/forums/topic/191804-toyo-proxy-4/#findComment-3450093
How much are the T1Rs?
https://www.sau.com.au/forums/topic/191804-toyo-proxy-4/#findComment-3450192
Im selling t1rs : http://www.skylinesaustralia.com/forums/t191861.html
I can honestly vouch and say they have really really really really good grip.. even in the wet!!
The threads on the t1rs dont wear quickly either which is a bonus!!
https://www.sau.com.au/forums/topic/191804-toyo-proxy-4/#findComment-3450732
Yeah just realised, they use proxes 4's in the DA drift series, not all the cars though obviously.
Does that mean that they're better for grip or slip?
Do they not use T1R's because they're too grippy?
Nah they are the best value vs grip, drifted on the T1R"s and they are not much differrent but in a grip environment i cant comment. ive only ever used Proxes 4, R888 and the RA-1's for grip.
https://www.sau.com.au/forums/topic/191804-toyo-proxy-4/#findComment-3455704
    • Yeah, you need to do it properly. You need to start out slow and gentle, ramping it up until they are good and hot, but not cooking, then roll off the other side (instead of letting them cool down quick).
    • I think yeah less hot fuel dumping into the top of the tank that wants to evaporate easily, fewer connections/hoses for permeation. Something like that. Also lower cost/easier production. Even my 2000 LS400/Celsior is a deadhead system. A single fuel hose to the fuel rails which have pulsation dampers attached and no return line.
    • I might do a few more high temp bed ins as described here.  I have a nice quiet 80kph road right near me.  How To Bed-In Your EBC Brakes For Street Or Track Use - EBC Brakes https://share.google/AjnOTILXoiqQnLu8p
    • I did a few 80-0 stomps. I then just rode the brakes while I applied throttle for a while to get them nice and hot. I live on a big hill and have been down it a few times also with stomps and brake riding.
    • Biggest thing is you're okay!   It sounds like between the accident, and the drive home, it was a pretty torturous trip again! On the bright side, you took the opportunity to enjoy the event more from the perspective of a spectator, than as an entrant!   Sad to see so much damage to the car. It really has taken a HUGE hit in the front end. If/when you choose to repair, hopefully the rails are straight (At least from shock tower backwards). Hopefully the extra cage coming through there has save most of the chassis rails, and HOPEFULLY saved the motor too. Best of luck when you eventually get motivated to start pulling it down to check it all out
