Hey everyone whats up got a wideband problem and wanted to see if anyone on here could help me out. Car is a 95 gts-t mods are pod filter with cai, fmic, 3.5" turbo back exhaust with split dump no cat, boosted up to 12 psi, stock ecu and turbo with afc neo. Ok here is the prob got a PLX wideband O2 SENSOR installed the O2 sensor in the decat pipe wired it up correctly and everything got power and the instructions stated that no calibration is needed but if you let it get warm takes 45 sec and it is exposed just to normal air the display should read air did that and air appeared on the display. Now here is the dilemna ct the car on let it get warm reset my afc neo cause Im thinking all is good and I'll be able to tune the afr's myself so I let the car get to normal operating temp took a look at my display and it reads 19 now Im cruisn at 1500 rpm to try and get the afr's right for that rpm and the display says lean and the more gas I put in the the richer it gets but i set the afc neo to +50 and the lowest afr I got was 14.5 I think!!!! What the hell is goin on. I thought skylines with stock ecu ran rich why are my afr's so lean at cruise and I did it at idle and the same thing nothing below 14.5 WHEN I have added +50% on the afc neo and when I set it back to 0 it shows lean. Can any1 help?
https://www.sau.com.au/forums/topic/191841-wideband-o2-sensor-not-worth-a-fk/
Its possible that the sensor needs to be calibrated, i know with the better quality wb02 units you can calibrate the sensor.
Check the companys web site out and hope for the best, if you can i would return it and see the guys at wb02 and get a real sensor :P
If the sensor cannot be calibrated then it may be faulty and have to be returned.
What happens if you take the sensor out, turn it on wait for it to heat up, get a cigerete lighter and let the GAS ONLY escape over the sensor, do you get a reading at all? (do not light the lighter just let the gas go past the sensor)
If yo dont get a reading then and you cant calibrate it then its faulty.
Check the companys web site out and hope for the best, if you can i would return it and see the guys at wb02 and get a real sensor :)
Sorry didnt know where to put it so I placed it twice its a plx wb and it is supposed to be self calibrated. If I let it heat up by itself in open air it goes from 14.6 to 20 to lean to air and thats what the wibesite says it should do. If I then blow on it it reads lean again what the site says it should do, also it does get warm when the power is switched to on and if i disconnect the display reader from the O2 sensor it reads 14.6 again thats what the site says it should do. Now when I start my car and let it idle the display goes from 14.6 to lean when it reaches norm operating temp and the more fuel I add via afc neo the richer it gets but at the most fuel I can add the display reads 14.6 and I bet if i were to leave it there it would eventually read rich. I was wondering if i just have the O2 sensor to far back I have placed it right before the cat.
I have a PLX wideband on my car and it works fine. It does the same things that yours does when not connected etc.
When I had mine dyno tuned - the PLX matched the Dyno Lamda - so all good for me.
I placed my sensor before the cat - and the just after the dump pipe flange.
Ensure the sensor is between 10:00 and 2:00 - the can't be upside down (ie 6:00) as water can get in them.
I'd suggest getting some dyno time with another wideband up the arse of your exhaust as a check and reference.
PS - no need to calibrate mine..... (as you say, they don't need it)
I only have a question for you in the instruction manual it says when the O2 sensor has reached operating temp air should be displayed on the reader and the white wire should have 5 volts on it. Now i sat in my car for bout five mins and let the O2 sensor get heated and when I checked the white wire all I got was 0.41 volts. I want to know how long it takes for the O2 sensor to reach normal temp and since this seems to b the prob what do I do replace the O2 sensor or the reader? Also my sensor is prob at 3:00.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
