for the 18" track wheels from Nissan they retail for about $600 each. 2nd hand ones on ebay or around the forums in good condition can be picked up for roughly $600-$800 full set w/o tires
I am pretty sure the 'track' rims (18x8) are $1100 each from Nissan. Anniversary are even more still!
But touring rims (17x8) you might be able to pick up for $600 each from Nissan. Though they don't look near as good imo.
For a mint set (no gutter rash, scratches, scuffs or damage) of 18x8 track rims you are looking at $900-$1000 a set. Not bad considering they are $4,400 new from Nissan! :spank: But these are extremely rare to find in pristine condition. There are a few around that have damage that can be had for $700-$800, but it's worth the extra dough for the undamaged ones because you will always notice the gutter rash etc on the cheaper set and it will be a constant eye sore. :)
BTW the track rims look awesome on any Nissan. They are probably the most versatile rim in the whole Nissan range that look good on every car. :) Seen them on R32, R33, R34, S13, S14, S15, 180SX, 300ZX etc and they all looked awesome. They actually look better on Skylines, Silvias, 180SX's & 300ZX's then they do on the 350Z!
Edited by HotPlates
https://www.sau.com.au/forums/topic/191959-350z-rims/#findComment-3463910
How do ya know which ones are the track wheels? Are they the 18x8 wheels? Or is there a specific lightweight version? Cheers and sorry for the thread hijack. :)
Touring are 17x8 and are 7 spoke (least expensive)
Track are 18x8 and are 6 spoke
Anniversary are 18x8 and are 5 spoke (most expensive)
https://www.sau.com.au/forums/topic/191959-350z-rims/#findComment-3463945
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
