O really?
How come they are such a major issue for everyone else then?
If you are relying on a north Brisbane RAWS shop to sell you the evidence, you could be (like Muz and me) waiting for a very long time.
If you already have the evidence I will send you my car for compliancing...
Ditto for me too! But I guess we both know the outcome hey Matt!
Hey Matthew,
I just had another thought, is there some way I can charge the "import broker" for the depreciation on the unused car? :(
You bet! When and if we get to court, this will be one of the myriad costs I will be suing them for - as well as liquidated damages such as loss of earned interest etc.
O really?
coz as the sayign goes its not what you know its who you know... had major dramas with the emissions on my ferrari but theres "loopholes" that just need emphasizing which is how il be doing the emissions for the M35
2002 Stagea can already be complied as all the testing has already been done! Post 11/2003 is the real issue as they have to meet the more (apparently) stringent ADR 79 standards.
As I said on the phone, you will have no problems with the 2002 car as it already complies.
no stress murray il find some other avenue out of this and get back to you
If you are able to find 'some other avenue out of this' I assure you I will very much make it worth your while, and no doubt Murray too.
Please be encouraged to apply the most rigorous 'lateral thinking' :worship:
I'd interested in seeing how this all goes. i wish you guys all the best!
i'm still keen on getting myself an axis and if it can be 04 then that would be great!
Would you like to buy mine?
You can have it for what I paid for it - I'll pay the freight to you.
As long as you don't mind waiting for compliance...
Edited by autech_axis
Haha, i've troubles with my paperweight at the moment!
no more cars needed for now :)
but thanks for the offer.... i think??
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
