R33 GTS-T Series 2 (May 1996)
Milage:100xxx km's
Colour: Silver
Manual Transmission
Can supply RWC
Currently registered till 07/08
Price: $24000
Contact:By PM
Mods
ENGINE
Autronic SM4 ECU
Autronic Boost Controller
Garret GT28/40 – 440HP Turbo
Greddy Intake Plenum
Custom 80mm Throttle Body
Custom Low Mount Manifold
Hybrid GT Spec Intercooler
Custom 3” Cooler Piping
Custom 4” Air Intake
Blitz 3” Cat Back Exhaust
Blitz 3” Header Pipe
Metal Cat 3” Cat Converter
Custom 3” Dump pipe
Sard Fuel Regulator with fuel pressure gauge
Blitz 550cc Injectors
Bosch 040 Fuel Pump
Splitfire Coils
Turbosmart 38mm Dual BOV (plumback)
4” Drift Air Filter
2 x Drift Breather Filters
Drift Stainless Oil Catch Can
Polished Rocker Covers
GTR N1 Water Pump
New Standard Thermostat
Cooling Pro 40mm 3 Core Alloy Radiator
Billet Lightwieght Flywheel
NPC Clutch - Button Clutch for 350 - 400rwkw
HANDLING
Front Strut Brace
Genuine R33 GTR Rear Strut Brace
Circlip Adjustable Bilstein Shocks (350mm center to guard at all 4 wheels)
King Springs
Front and Rear Swaybar - Heavy Duty (Blade Adjustable)
Front Upper Control Arm Camber Bushes
Front Castor Rod Bushes (Offset tube for Adjustment)
Rear Upper Control Arm Camber Bushes
Pineapples for Rear Crossmember
Manaray VR5 Rims – 17x8 Front, 17X9 Rear
ICE
Mongoose M80 Alarm and Immobiliser (winds windows up when locks)
Alpine MP3 Head unit
Alpine Type S 6x9
Alpine Type S 6” Splits
Alpine Tweeters
Alpine 4 Channel Amp
Alpine Mono Amp
Alpine Type S Sub
Alpine iPOD Adapter
OTHER
Clear Blue Headlights bulbs
Custom 3 Gauge holder (below aircon controls)
Drift Mirror A/F Gauge
Drift Mirror Oil Pressure Gauge
Drift Mirror Boost Gauge
Midnight Black Window Tint
Painted Dash Insert
I have purchased a body kit but haven't put it on yet, these also can be purchased with the car if requested.
Edited by 33_skyline
https://www.sau.com.au/forums/topic/192027-r33-gts-t/
  • 4 weeks later...
  • 4 weeks later...
  • 10 months later...
Thought I would bump this again
The car still needs a performance tune, being autronic it isn't the easiest to
get done where I live.
I have done more mods since first posted
King Springs
Bosch 040 Fuel Pump
PRICE: $20,000 ono
It also has a crack in the front bar, I have attached a pic
https://www.sau.com.au/forums/topic/192027-r33-gts-t/#findComment-4284886
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
