R33 GTS-T Series 2 (May 1996)
Milage:100xxx km's
Colour: Silver
Manual Transmission
Can supply RWC
Currently registered till 07/08
Price: $24000
Contact:By PM
Mods
ENGINE
Autronic SM4 ECU
Autronic Boost Controller
Garret GT28/40 – 440HP Turbo
Greddy Intake Plenum
Custom 80mm Throttle Body
Custom Low Mount Manifold
Hybrid GT Spec Intercooler
Custom 3” Cooler Piping
Custom 4” Air Intake
Blitz 3” Cat Back Exhaust
Blitz 3” Header Pipe
Metal Cat 3” Cat Converter
Custom 3” Dump pipe
Sard Fuel Regulator with fuel pressure gauge
Blitz 550cc Injectors
Bosch 040 Fuel Pump
Splitfire Coils
Turbosmart 38mm Dual BOV (plumback)
4” Drift Air Filter
2 x Drift Breather Filters
Drift Stainless Oil Catch Can
Polished Rocker Covers
GTR N1 Water Pump
New Standard Thermostat
Cooling Pro 40mm 3 Core Alloy Radiator
Billet Lightwieght Flywheel
NPC Clutch - Button Clutch for 350 - 400rwkw
HANDLING
Front Strut Brace
Genuine R33 GTR Rear Strut Brace
Circlip Adjustable Bilstein Shocks (350mm center to guard at all 4 wheels)
King Springs
Front and Rear Swaybar - Heavy Duty (Blade Adjustable)
Front Upper Control Arm Camber Bushes
Front Castor Rod Bushes (Offset tube for Adjustment)
Rear Upper Control Arm Camber Bushes
Pineapples for Rear Crossmember
Manaray VR5 Rims – 17x8 Front, 17X9 Rear
ICE
Mongoose M80 Alarm and Immobiliser (winds windows up when locks)
Alpine MP3 Head unit
Alpine Type S 6x9
Alpine Type S 6” Splits
Alpine Tweeters
Alpine 4 Channel Amp
Alpine Mono Amp
Alpine Type S Sub
Alpine iPOD Adapter
OTHER
Clear Blue Headlights bulbs
Custom 3 Gauge holder (below aircon controls)
Drift Mirror A/F Gauge
Drift Mirror Oil Pressure Gauge
Drift Mirror Boost Gauge
Midnight Black Window Tint
Painted Dash Insert
I have purchased a body kit but haven't put it on yet, these also can be purchased with the car if requested.
Edited by 33_skyline
https://www.sau.com.au/forums/topic/192027-r33-gts-t/
  • 4 weeks later...
  • 4 weeks later...
  • 10 months later...
Thought I would bump this again
The car still needs a performance tune, being autronic it isn't the easiest to
get done where I live.
I have done more mods since first posted
King Springs
Bosch 040 Fuel Pump
PRICE: $20,000 ono
It also has a crack in the front bar, I have attached a pic
https://www.sau.com.au/forums/topic/192027-r33-gts-t/#findComment-4284886
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
