R33 GTS-T Series 2 (May 1996)
Milage:100xxx km's
Colour: Silver
Manual Transmission
Can supply RWC
Currently registered till 07/08
Price: $24000
Contact:By PM
Mods
ENGINE
Autronic SM4 ECU
Autronic Boost Controller
Garret GT28/40 – 440HP Turbo
Greddy Intake Plenum
Custom 80mm Throttle Body
Custom Low Mount Manifold
Hybrid GT Spec Intercooler
Custom 3” Cooler Piping
Custom 4” Air Intake
Blitz 3” Cat Back Exhaust
Blitz 3” Header Pipe
Metal Cat 3” Cat Converter
Custom 3” Dump pipe
Sard Fuel Regulator with fuel pressure gauge
Blitz 550cc Injectors
Bosch 040 Fuel Pump
Splitfire Coils
Turbosmart 38mm Dual BOV (plumback)
4” Drift Air Filter
2 x Drift Breather Filters
Drift Stainless Oil Catch Can
Polished Rocker Covers
GTR N1 Water Pump
New Standard Thermostat
Cooling Pro 40mm 3 Core Alloy Radiator
Billet Lightwieght Flywheel
NPC Clutch - Button Clutch for 350 - 400rwkw
HANDLING
Front Strut Brace
Genuine R33 GTR Rear Strut Brace
Circlip Adjustable Bilstein Shocks (350mm center to guard at all 4 wheels)
King Springs
Front and Rear Swaybar - Heavy Duty (Blade Adjustable)
Front Upper Control Arm Camber Bushes
Front Castor Rod Bushes (Offset tube for Adjustment)
Rear Upper Control Arm Camber Bushes
Pineapples for Rear Crossmember
Manaray VR5 Rims – 17x8 Front, 17X9 Rear
ICE
Mongoose M80 Alarm and Immobiliser (winds windows up when locks)
Alpine MP3 Head unit
Alpine Type S 6x9
Alpine Type S 6” Splits
Alpine Tweeters
Alpine 4 Channel Amp
Alpine Mono Amp
Alpine Type S Sub
Alpine iPOD Adapter
OTHER
Clear Blue Headlights bulbs
Custom 3 Gauge holder (below aircon controls)
Drift Mirror A/F Gauge
Drift Mirror Oil Pressure Gauge
Drift Mirror Boost Gauge
Midnight Black Window Tint
Painted Dash Insert
I have purchased a body kit but haven't put it on yet, these also can be purchased with the car if requested.
Edited by 33_skyline
https://www.sau.com.au/forums/topic/192027-r33-gts-t/
  • 4 weeks later...
  • 4 weeks later...
  • 10 months later...
Thought I would bump this again
The car still needs a performance tune, being autronic it isn't the easiest to
get done where I live.
I have done more mods since first posted
King Springs
Bosch 040 Fuel Pump
PRICE: $20,000 ono
It also has a crack in the front bar, I have attached a pic
https://www.sau.com.au/forums/topic/192027-r33-gts-t/#findComment-4284886
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
