I recently blew my intake manifold appart and have sine had it welded back together and i have fitted it and the car starts perfectly but when the turbo starts to spool it stutters and wont build up any boost even if i hold the pedal down it wont pick up. i know this isnt the greeatest description but i dont know how else to describe it.
Cheers Ryan
https://www.sau.com.au/forums/topic/192274-problem-coming-on-boost/
If there's a vac leak it'll hunt at idle.
If there's a boost leak, it'll lose boost and splutter and backfire and run rich, and just accelerate like a bogged down dog.
(I keep a copy of this so I don't have to type it everytime)
You can do a leak test.
What you'll have to do is,
1. take your pod and AFM off.
2. use a baked bean can (full) and put it into your rubber intake pipe (assuming its still the stock one).
3. tighten up the hose clamp onto the tin creating a seal.
4. Open the throttle body with a brick on the accelerator pedal, so you can read pressure on the boost gauge.
5. take a hose that is plumbed into your intake between the turbo and the plenum or off the plenum itself.
6. Get an air compressor and pressurize the system through the hose and get someone to read the psi on the boost gauge. you only need about 5psi. you can use the compressors at the servos.
7. Listen for a leak. And use the soapy water in the spray bottle to find exactly where it is if need be.
It is easier to find a boost or pressure leak using this method because the car is not running and is easier to hear and locate.
Yeah it runs fine off boost till 4000 odd rpm or so. Its when there's enough boost to open up whatever(usually a intercooler join) it is and leak out pressure.
Boost bleeds off and it runs rich and just feels like it doesn't want to accelerate.
If you've touched you IC piping recently, then there's a good chance the piping connections aren't on properly or weren't done up tight enough, so it blows open under boost. Otherwise a joiner may have a split in it.
positive that the plumbing is good, we have come up with another theory, that maybe the fuel pressure reg isnt working becoz its possibly leaning out as it comes on boost. We did a bit of a test today and if i let the revs creep up slowly to 4500k then give it a bit it isnt as bad but if i nail it at 3k and let it try and wind up it hates it. Any thoughts on this.?
by the way the pump is all good as it is a 5.7ltr pump and yet to check the filter
Edited by mad032
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
