  • Replies 71
It was a terrific day and made an otherwise mundane job a whole lotta fun. Thank you to Donnan and his 'boss' for allowing us to use their carpark which was perfect for the occasion.
We should make a regular of this, every 4-6 months would keep our cars boootiful.
    • I got a full sheet set of OEM copied stickers to replace all the faded engine bay ones, great quality too.  Came from England. Someone like that should be able to to make u up what u want so long as u have a quality image to show them 🤷🏻‍♂️
