  • Replies 71
It was a terrific day and made an otherwise mundane job a whole lotta fun. Thank you to Donnan and his 'boss' for allowing us to use their carpark which was perfect for the occasion.
We should make a regular of this, every 4-6 months would keep our cars boootiful.
