Im Searching for the Following Things:
Complete RB25DET from sump to cam covers including manifolds.
It doesnt need to have the turbo or fuel rail or coil packs. But would be Handy if they are supplied.
The Motor needs to be completly stock but it doesn't matter if it's blown or damaged as long as it's fixable.
Stock intercooler and pipework.
I also have a Complete RB30E for sale that has been pulled down. Make me an offer. was going to build a 30/25 engine but plans have changed.
R33 Gtr Bodykit. Would prefer genuine plastic kit. but would look into F/G copies.
In the next 6-12 months i will have the following for sale:
Greddy style plenum,
FMIC with modified piping to suit greddy plenum
Complete RB25det unopened
full Trust Style bodykit
ANZ 17" Rims with Tires.
Standard Front Brake Calipers, rotors and new pads.
Tein HR Coilovers.
i can be contacted on 0408126063 or emailed at [email protected] or messaged on the forums.
https://www.sau.com.au/forums/topic/192691-wtb-various-engine-bits/
Hmmmm... going on ere then?? well i cant help with the bits u need but I may take the plenum (depending), rims and we can always talk about the engine....
Edited by madaz R33
hey,
i have a near complete series 1 25... only things missing are crank angle sensor, throttle body and turbo...
noisey big end bearing and lacking compression in 6th cylinder (hasnt been pulled down to see why)... couldnt be assed fixing it so i just imported another motor :)
Edited by toffaz
hey,
Thats fine. how much do you want for the Motor? the missing parts are no issue. if you want to keep the fuel rail or coil packs i don't mind.
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
