Hey Guys
Im looking to sell my white 1995Mdl R33 GT-R, the car is in excellent condition both mechanically and externally. An extensive amount of work has been done to this car and it is in pristine condition. The car is very reliable and had a full forged engine rebuild less than 10000kms ago. Reason for the rebuild was to be able to make reliable power that will last a long time. The car can speak for itself no expense has been spared. If you want an all round GT-R that can be driven on the street, and taken to the drags and still be a serious circuit competitor than this car is for you. The car has not been raced although it has been to the drags on one occasion in which it ran a The car makes a genuine easy 350rwkw on Bp ultimate and is exremely reliable. I am the second owner and the car has been in Australia for more than 4 years and has been looked after and love by both myself and the previous owner. I am selling as I am currently building and would like the extra finances to help out. I am open to trades so feel free to email me an prospective trade in.
The list of modifications are as follows:
Engine Modifications:
CP pistons
Shot peened rods
ARP studs
N1 water and oil pump
Tomei Head Gasket kit
Tomei Sump baffle kit
Tomei Poncams
Tomei Cam Gears
Tomei Expreme exhaust manifolds
HKS GT25/10s Turbos
HKS Air filters
HKS DUMP PIPES
HKS TWIN race spec exhaust
HKS GT FMIC bar and plate core
Split fire Coilpacks
Sard 700cc injectors
Sard Fuel rail
Sard Fuel regulator
Braided lines off Y-block for above setup
NISMO intank fuel PUMP
Greddy Aluminium Radiator
Greddy Oil cooler and relocation Kit
OS twin plate
Exterior:
Volk Racing TE37's 18*9.5
Proper HDI headlights
Custom rocker covers with Tomei centre and greddy oil caps
NISMO clear side indicators
NISMO front bonnet lip
Interior:
NISMO White faced dials (have original speedo)
DEFI TWIN White faced oil pressure and boost dials with link control
APEXI Black faced AVCR
APEXI Power FC Commander
APEXI Power FC
PIONEER MP3 player with Bluetooth handsfree connected to five channel amp and hi end speakers
NISMO Steering wheel
Suspension\Handling:
Tein Monos
Tien pillow ball tension rods
Whiteline Sway front and back
Cusco Front Strut Brace
Endless Brake Pads
Braided Brake lines
AP slotted front discs
DBA slotted and drilled rear discs
Probabley left out a few things but that gives you a good idea. If interested please call or pm me
If you are after a reliable high performance all round GT-R, then you cannot go past this car, and the amount of money needed to get a car from stock to this standard and the time is a lot more than the asking price. My loss is your gain.
Price: $44,750 Negotiable (feel free to make offers and will be interested in trades) even motorbike :D
Phone: Raymond 0422 977 116
Email: [email protected]
If you have any questions feel free to get in touch with me, the car has rego till september 2008. Pics up.... I have more and can organise more for more interested parties....
https://www.sau.com.au/forums/topic/192900-modified-r33-gtr/
^^ Thanks mate, yeah nah the minute i came up with it I bought it within that minute, suprised it wasnt taken. Umm to be honest I dont really mind obviously the right adjustment is needed, but feel free to put forward some ideas.
In regards to insurance, Shannons will cover you no problem, if you are over 25 ur looking at 1100 for full comprehensive, if below 25 then looking at 1800-2200 oh and just cars will cover you also.
Cheers
Ray
  • 1 month later...
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
