044 or 040 will do the job..
044 has a higher flow rating but its generally used as an external pump. Mods (nothing major) can be done to the bracket and pickup filter to made it work internaly.
040 is a pretty straight forward replacement.
Cheers,
https://www.sau.com.au/forums/topic/193089-bosch-fuel-pump/#findComment-3466585
Me and another skyliner on here bought a couple Tomei pumps and it was friggin easy to install.. slid right in and comes with o-ring and couple other little bits and has a pickup.. the bosch ones dont. Took about 1 hr to install.
https://www.sau.com.au/forums/topic/193089-bosch-fuel-pump/#findComment-3468380
what are the tomei pumps rated at? (hp) looking for something around the 350rwhp-400rwhp mark in tank though so most probably leaning towards the 040 pump.Also where did you get the tomei pump from? how much?
Edited by showbizz
https://www.sau.com.au/forums/topic/193089-bosch-fuel-pump/#findComment-3468575
1 hour and a pint of blood. HaHa, if ur changing the pump urself watch the metal when ur twisting the retaining ring off......and fuel doesnt help cuts either. LoL
the bosch fuel pumps need to have the fittings and brackets modified whereas the tomei ones dont...also alot quieter than the bosch ones to, doesnt sound like bee's inside ur fuel tank. also like ryan said, everything is supplied....plugs straight in....all sweet
https://www.sau.com.au/forums/topic/193089-bosch-fuel-pump/#findComment-3468812
cuts and fuel (niiiiiiiiiiiiiiice) haha, yeah i get ya would be easier to install the tomei by sounds of things, if i go with bosch 040 just probably take it in to a workshop to fit it saves me the effort will ring a few workshops later see what the prices are like for fitment.
https://www.sau.com.au/forums/topic/193089-bosch-fuel-pump/#findComment-3468860
haha just called up ovaboost they charge $100-$120 to fit the 040 and the pump is $200 so thats still cheaper, but i dont know what the ratings off the tomei 1 are but im sure they are a good pump any ways going with 040 thanks for the input dudes look out for a r33 with a 040 on the street soon LOL just kidding :angry:
https://www.sau.com.au/forums/topic/193089-bosch-fuel-pump/#findComment-3468895
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
