Guest wilco
Yar I got all the details, the witness etc, gonna make them pay up :P
The problem really is the back suspension took a big knock when they hit me in the side, moved the whole back end over to the right a few inches, going in for a check-up by the insurance company Wednesday.
What happened with you?
https://www.sau.com.au/forums/topic/19313-cruise/#findComment-418643
Guest wilco
Some guy was driving, he looked stoned or pissed or something but the cops didn't want to attend the scene. Female passenger who owned the car and did all the talking furthering my thoughts the driver was on something.
I would say there is a bit more than 2k on this one, they have written down a lot of stuff to replace, will see the quote on Wednesday when I head back down there.
Freakin retards everywhere. Two months ago I was tail ended at a railway crossing by some fool when I slowed down for the car in front of me to cross it, I was almost stopped and had been for about 2 or 3 seconds and the clown slammed the brakes and slid into my back end, just one wide scratch which polished out, but still - retard.
https://www.sau.com.au/forums/topic/19313-cruise/#findComment-418709
Guest wilco
Lots of women I know admit to being terrible drivers, my own girlfriend told me she is one of the worst drivers she knows and said if she were cleaned up n the side as I was yesterday that she would have turned right (into oncoming traffic) to try and get away from the other car!!
:P
I think good female drivers are an endangered species, but that is certainly not to say a good % of male drivers are shit house too.
I shall stop this dicussion now :)
https://www.sau.com.au/forums/topic/19313-cruise/#findComment-418799
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
