Hi,
I have an R32GTS4 with an RB20DET. I have bought an R34 GTT turbo which I hope to install shortly. The turbo I have bought has the larger OP6 exhaust housing. I understand from many other threads that using the smaller exhaust housing from an R33GST25T on my R34GTT turbo will be less laggy.
My logic / thinking is - if an R33GST25T exhaust housing is smaller than an R34GTT exhaust housing which means less lag, would an R32GTST exhaust housing which is even smaller (that the R33GTS25T) be even less laggier?
If so, would using the RB20DET ex housing mean any / much less power?
Any help / advice would be ver much appreciated.
Thanks,
Ben.
If you are worried about lag then save up for an RB25 engine swap, the RB20 has quite a reputation as being somewhat laggy.
What you are saying is correct, the smaller the exhaust housing (generally) the better the response, but at the cost of top end power.
In any event, none of the turbos you suggest will be very laggy, and I would suggest using the OP6. The rb20 turbo will limit you to about 170ish rwkw, the RB25 to 190ish and the OP6 to about 200. All on about 13psi, so pick the power you want and go for it.
Just be prepared to get teh power bug and want to upgrade again.
Good luck.
I had a s1 R33 turbo on my RB20 and it made 183rwkw @ 12psi and was making full boost by about 3500rpm. Same turbo on my RB30 makes full boost by about 2200rpm and makes the same power at the same boost but about 1500rpm sooner.
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
