  • Replies 42
they remove the HID bulb and ballast, and replace with standard bulb.
Find yourself a cheap aftermarket set and hook up HID again! :wave:
so you mean there is no difference between normal headlight unit and xenon head light unit other than removed original ballast and HID bulb?
so if i buy aftermarket HID kit and install onto my headlights it wont glare as much as r33 which they dont have xenon headlight houseing.????
cheers
Edited by tyaos
https://www.sau.com.au/forums/topic/193386-head-lights-r34/#findComment-3470667
Your headlight probably had HID globes in them from factory (that's why you've got the 'xenon' printed), but there's a high chance that the compliance company took them out and put halogen globes in.
To check whether or not you've got HID globe installed at the moment, check around the headlight to see if there's a ballast mounted somewhere. Or you can just switch on your headlights and see if they come on straight away or not. If they come straight on to the normal colour, they're halogen, but if they look like they 'power up' in the first 2 secs, then it's probably HID's.
Make sure the globes are cold when you test this way.
Hope that made some sense.
https://www.sau.com.au/forums/topic/193386-head-lights-r34/#findComment-3470791
f**k, why didn't I think of this before....
Just take your existing globes out, if they look like normal halogen globes, they're halogen, but if they look like a tube with a little 'bulge' in the middle, they're HID.
Post up a pick if you're not sure.
https://www.sau.com.au/forums/topic/193386-head-lights-r34/#findComment-3470794
lol thanks adam!!
so there is no difference between normal halogen headlight house and HID headlight house?
i know i have normal harlogen light bulb cz i changed light bulb last time myself...
as long as there is no differnce between those two light housing... that means i can possibly put HID kit onto my
headlight right????
SO NON-XENON HEADLIGHT UNIT AND XENON HEADLIGHT UNIT ARE THE SAME UNIT BUT XENON HEADLIGHT UNIT HAS BALLAST INSTALLED AND NON-XENON HAS NO BALLAST.. AM I RIGHT?
AND IF IM RIGHT there is no such things as OEM xenon r34 headlight unit right?
all head light units are same but the fact that ballast is in it or not...
than why people selling oem xenon headlight unit and why people buy that?
why dont they just buy HID kit and install them??????????
https://www.sau.com.au/forums/topic/193386-head-lights-r34/#findComment-3470844
No, no umm, I think there would be some 34 headlight housings which only came with halogen globes, but if your headlight has the 'xenon' printed, it had HID's installed back in Japan, but the compliance people took them out because they're illegal on Australian roads.
If you've got the 'xenon' printed and you plan on putting HID's back in, you can, you just have to make sure you get the genuine HID system that came with the 34's. You can't throw those cheap HID kits in for example.
Headlight housings which came with HID's will have a different reflector design to those without HID. The two globes produce light in a different position. If 34's ever came with halogens from factory, there will be two different types of housings on the market.
https://www.sau.com.au/forums/topic/193386-head-lights-r34/#findComment-3470872
As long as you get globes that are the same as the genuine ones I don't see a problem. For example, if you're headlight originally took D2S globes, you must get D2S globes for your headlights to perform at their best, but that's a bit obvious, I didn't have to explain that. :wave:
Good luck, I hope you find a set of globes and ballast at a good price.
https://www.sau.com.au/forums/topic/193386-head-lights-r34/#findComment-3470927
There are 2 TYPES of FACTORY headlight 'assembly'. One if factory halogen, one is factory Xenon.
Xenon is defined by the embossed 'Xenon' on the front/horizontal part of the assembly. The two assemblies in general look quite different.
The Xenon reflectors are designed for a D2R globe light pattern ONLY. In other words, an H1 Xenon globe will produce some glare and will not have the same quality as a D2R globe even though both will be HID lighting.
You can get away with an aftermarket HID kit in the R34 Xenon assembly, but the light output isn't the prettiest. I wonder if the light output is better on the factory halogen assembly?
Anyways, hope that clears it up for ya
https://www.sau.com.au/forums/topic/193386-head-lights-r34/#findComment-3472342
Hey guys I have been trying to sort out my missing high beam bulb problem for a few weeks but everywhere i take my spare bulb(3rd pic), they just look at it very wierdly. I hope that buy just looking at these pictures somebody might tell me what i need to buy to replace the missing bulb. The casing of my lights say Xenon.
I need the bulb and the black bit connected to it (everything in 3rd pic), which then connects to the casing(1st n 2nd pic).. If anyone can help me i would appreciate it very much. im exhausted in looking around and i need to take the car over the pits and register it.
By reading this forum Im gona search my car 2moro for hid ballasts..
low beams flick on straight away and are not that bright so must be halogen?
If I buy a pair of new Hid ballasts, will that fix my problem? what ballast do i buy?
Is there a limit to how legal the power of the bulbs?.. ( taking car over pits)
Sorry about all the questions but Ive never dealt with xenon or any hid lighting before. Cheers!
Edited by MellowYellow
https://www.sau.com.au/forums/topic/193386-head-lights-r34/#findComment-3472768
the R34's Hi beams are HID right? they look like it by looking....
so have to get D2R bulb to get perfect output???? most of cheap HIDs on Ebay market are H Type not D type..
can anyone recommend decent good HID kit for r34 with D2R bulb?
paul
https://www.sau.com.au/forums/topic/193386-head-lights-r34/#findComment-3472945
paul
To get the most out of your original HID housing, get the D2R globes (assuming that they're the factory style).
You can get those cheap HID kits with D2R on ebay, but you said 'decent', not sure if those will be.
https://www.sau.com.au/forums/topic/193386-head-lights-r34/#findComment-3474233
i have no idea why i didn't think about this, but is there anything stopping us R34 owners with Xenon assembly's, but hacked due to compliance, from getting D2R kits and get an OEM light output?????
I thought i wrote this idea off for some reason, but can't remember why....
https://www.sau.com.au/forums/topic/193386-head-lights-r34/#findComment-3474555
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
